lee_worsdell's avatar
lee_worsdell
dishnet work
does any one no if dish network works in Canada. I want to purchase a dish vip 2112 receiver from camping world. I have a winegaurd carry out dish so wondering if the dish will work when iam at home in Canada. We will be taking a few trips south this summer so I need my nascar fix on sundays when were away
    This may help.
    Clicky
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    powderman426 wrote:
    Canada is a big place. Do a search for " Dish footprint". To see if it will work where your at. They have really trimmed the footprint down so it is unlikely it will work unless close to the border.
    Best advice given... WIll it work in Canada is a question we can not possibly answer without knowing where in Canada.. For example.. Windsor, Likely yes since that is actually SOUTH of Detroit.
    Yukon.. Not so sure.
  • I have dish at home. I bought a 211 receiver and dish 3 head antenna off of the internet. Then I called dish to have it turned on. They would have given me the 211 receiver, the dish and all the cable for $50.00 The tech did give me an addition dish antenna and portable stand to mount it on.
  • Yes DISH should work in your location, Phelpston Ontario. At your location using the DISH Eastern Arc satellites, 61.5-72.7-77, you will have an elevation angle of approximately 38 degrees. This site angle should get you over most obstacles. To give you a height reference, at a distance of 50.0M from the antenna you would clear a 39.3M obstacle.
  • When traveling back up to Alaska from the west coast, we lost Dish service within a couple hundred miles of the Washington border with our 18" dish. We have a single-LNB 30" dish that works all the way up to Anchorage as long as there aren't mountains in the way. The Dish satellites are very low on the horizon up there.
    The little Winegard Carryout dish is not going to work very far north of the border.
  • Canada is a big place. Do a search for " Dish footprint". To see if it will work where your at. They have really trimmed the footprint down so it is unlikely it will work unless close to the border.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,807 PostsLatest Activity: Sep 06, 2026
