Roadpilot wrote:
While I think the RF interference is likely, another possible explanation is a changing VSWR. The impedance if the TV antenna is likely 75 or 300 ohms. The cable maybe 60 ohms or 50 ohms or 300 ohms if it's a flat cable. The splitter if used is unknown and then there is the input impedance or termination impedance. Unless all these impedances are equal you get interactions from a voltage standing wave ratio reflected back towards the source and then to a downstream device.
No.
SWR and impedance DOES NOT COME INTO PLAY when it comes to RECEPTION.
TRANSMITTING, yes, RECEIVING, NO.
The antenna input circuits of a tuner does not change impedance when powered or not powered. The tuner inputs are typically FET semiconductors which have an inherent HIGH IMPEDANCE to start with. The input of the TV is buffered via a resistive, capacitive and inductive network that presents a nominal 75 ohm impedance whether the TV is on or off.
If what you state is really true then the OP would be LOOSING ALL channels, not SPOT channels nor in the OPs case DIFFERENT channels are affected depending on what TV is turn on.
I have SEVEN, thats right SEVEN TVS in my sticks and bricks all running off the SAME outside antenna PLUS a FM tuner for the whole house audio system..
I have no problems or issues loosing channels when one or all are turned on.
What I did have was my system performed perfectly well for TV when it was ANALOG NTSC TV broadcasts and my system was setup using PASSIVE splitters.
Once the broadcasts switched to DIGITAL ATSC my splitters caused to much signal loss and all but a couple of stations were to weak.
My eight port passive splitter had too much signal loss in my case, had nothing to do with quantity of TVs or if they were on or off.
The fix I found in my case was replacing the passive splitter with a amplified coupler which gives a small amplified gain on each output of the coupler.
In a RV you have either a non amplified antenna or a amplified antenna PLUS one two way PASSIVE splitter.
Passive splitters are nothing more that a simple resistor inside the box, for two way splitters they are 75 ohm resistors which are in series with the output.. That makes each TV appear to be 150 ohms and with two TVs in parallel you now have 75 ohms (Ohms law).
Does not matter whether you spend $1 or $100 on a passive splitter, they ALL use RESISTORS which means signal loss.
The OP IS dealing with RFI which IS MOST LIKELY being generated within the TVs.
I suspect that the OPs TVs may have a power supply issue, specifically capacitors which ARE WEAK or going bad.
This is a typical problem that starts to surface after one or two years where the final filtering caps on the power supply board start to weaken and allow the high voltage/high FREQUENCY spikes generated by the switcher in the supply to not be filtered..
TV will work fine for several years then one day not power up, but in the mean time the TV radiates a lot of RFI, transmitting it throughout the TV and even into the wiring.
There are three main spots in a TV which use switching power supplies.
Main power, LCD driver and LED or fluorescent backlight driver.
Switching power supplies by their nature generate large amounts of RFI and the manufacturer must use care in the design of the switcher to minimize the RFI outside the TV.. But sometimes they skimp on the filtering and use components which are marginal to start with and when they age are no longer effective.
