Beaker's avatar
Beaker
DTV SWM
My portable HD setup came with a SWM. I don't use it.
What is it for?
  • You just add a splitter inside the coach (or near the coach) and you run 1 coax for each receiver from that location. Even a Genie with a whole bunch of tuners only requires 1 coax cable.
    It's pretty awesome!
  • SWM will also allow you to connect multiple receivers with only a single cable running to your dish.
    And how does this do it?
  • SWM will also allow you to connect multiple receivers with only a single cable running to your dish. Very handy when the dish is 50'+ from your rig.
  • Nearly all DTV receivers can use SWM. Only the SD receivers built early than the D12 model can utilize SWM. I think there was one HD receiver (H20 ish) that did not use SWM. If your portable has a SWM LNB you will be required to get a receiver that does use SWM. Sounds like a good time to update your hardware anyway.
  • For the latest DTV equipment. Older models were self powered, newer need a power supply and a splitter.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
