- Bill_SatelliteExplorer IINot sure what an F-53 is but if that's a 5er, I get that! My Genie has been running none stop for years and I travel 10-15,000 miles per year in a bus conversion.
- 2oldmanExplorer IIUgh. Years ago that happened, then they fixed it. Hope it's not back again.
- Pirate1Explorer
Bill.Satellite wrote:
Thought about that but wanted the hard drive in the dvr parked while driving. Too much bouncing in the F-53.
If you can keep the power on using an inverter while you travel you should not have this problem. You should report the problem to DirecTV is you find you are unable to access your program after power loss and no antenna connection. - Bill_SatelliteExplorer IIIf you can keep the power on using an inverter while you travel you should not have this problem. You should report the problem to DirecTV is you find you are unable to access your program after power loss and no antenna connection.
- YC_1NomadKeep on poking the menu button or the list button. Might come up.
- swphotobugExplorerI am following this.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Feb 08, 2025
