TenOC's avatar
TenOC
Nomad
Jul 13, 2018
Internet connection not working -- CAT5e
My RV is 300 feet from my S&B home. About 5 years ago I ran (in a pvc conduit) a underground gel filled CAT5e cable from the S&B to the RV. I got good service at the RV with about the same speed as at the S&B.
I have now returned from 6 weeks on the road. I no longer have internet service at the RV. I do not know if there was any type of storm damage or other thing that could have "knock out" the cable while I was on the road.
I have tested the cable and I get a "pass" with one of these tester.
CAT5 Tester
Even with a "good pass" cable I can not connect to the internet. Is there some other type of tester that I can use to find out what is wrong?
  • wa8yxm's avatar
    wa8yxm
    Explorer III
    300 Feet is not too far for wireless if you have a good Wi-Fi Client (Nano-Station Loco M or M2 as an example)
    300 Feet IS the limit for Cat-5 if I recall correctly.
    It may be the cable has gotten wet I have that issue when my 100' Cable gets wet.. Enough. You may just need to pull a new cable.
  • Time to pull a new cable. I suspect you will find the old one soaking wet. If you find it wet try to find a midway point in the conduit and drill a hole from top through the bottom once you pull the old cable out and just have a string attached.
    Then seal the top hole. It does not need to be any bigger than 1/8 of an inch drill bit.
    He did say that his original cable is gel filled, right ?
    Unless it is badly damaged, that should work completely submerged......right ??
    My bet is that the conduit and cable are crushed somewhere along the line, or similarly damaged. If that is the case, the old one might not pull out very good or at all. Or will have to be pulled in TWO pieces, one from each end.
    I still think that proper WiFi equipment might be a better option.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
