Maxi_Signal
Jun 07, 2015Explorer
Naio wrote:Maxi Signal wrote:Naio wrote:GordonThree wrote:
No db gain, not compatible with the primary band of your phone. If the phone has any signal on its primary band it will ignore other bands despite those being stronger.
Hmm...
It does 800/1900mhz and my phone is an Avant on tmobile. Did I google that wrong?
It does seem like it is doing stuff and my phone is ignoring it.
Tmobile voice is usually on 1900 mhz. Very rare they use 850mhz. Tmobile data is on 1700/2100 mhz if in a home area if roaming on AT&T network it is on 1900mhz.
Thanks! I noticed it said 'not roaming'.
So, the sleek is right for my phone, for voice, yes?
Should be. If you go to wirelessadvisor.com . Type in your zip code you can see what frequencies each carrier owns in a specific area
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,804 PostsLatest Activity: Apr 21, 2026
