dlos wrote:
Geez....
My crank up leaks and I can't stop it from doing so, this one gets torn off by branches.
Can't win here! We don't even watch the TV, would really just like to take it off, seal the hole and be done with it!
This may interest you:
Jack Antenna Mounting PlateUse when replacing an existing crank-up style antenna and mast assembly with a JACK antenna.
Covers all screw holes left by the old antenna for a water-tight seal. Durable ABS plastic is weather-resistant and UV-protected. Pre-drilled for easy installation. Attaches to base of JACK antenna with included hardware.
-remove the Bat Wing antenna
-cover the hole with the Jack Antenna Mounting Plate
-install the Jack Antenna on the mounting plate
-add self-leveling lap seal over all of the mounting screws. I'd probably cover the entire mounting plate with lap seal as well - for sun protection
The
Jack Antenna itself comes in white or black.
