The complete message is as follows:
"As of December 29 MyVerizon services will no longer be accessible for your device. Manage your account by visiting vzw.com/myverizon from your computer or dial the following # functions from your device. #BAL for balance or #PMT for payment"Since this is not a phone, you can not use the # functions.
To set up a MyVerizon account Verizon will send you a password via text message. My 4620 Jetpack does not receive texts messages so this won't work for me.
I plan on adding $5 on Dec 28 to stretch my service out as long as possible just in case calling in by phone no longer works.
Hopefully the phone option will continue to work.
If service comes to an end, one option may be to have my device reprogrammed by the following vendor:
http://www.ebay.com/itm/FLASH-YOUR-VERIZON-MIFI-JETPACK-TO-VERIZON-UNLIMITED-3G-REMOTELY-/232174352882?hash=item360eab79f2:g:-5gAAOSwV0RXuxm4They state in their listing:
Have Custom Software For All The Jetpacks and 2200 that enables you to flash the device the correct way and allow the flashed device to receive Text Messages and populate it's own data.If the device will receive text messages then you should be able set up a MyVerizon account.
