- dontexasExplorerIvylog Replaced the LNB as per your suggestions. First timer out and have 1 question. In setup what dish shape do I select ? Thanks
- IvylogExplorer III
Bill.Satellite wrote:
There is NO HD available with that antenna. It will only receive 101, 110 and 119 and you need 101 plus 99 and 103. 110 and 119 are no longer of much use.
OP, if you replace the current lnb (for 101, 110 and 119) with a SL3 lnb (99/101/103) it will work for HD. Because of it's smaller size (easy to store) in the northern states and Canada the signal may be too week to get HD but it will still get 101 (non HD). - chiefwardExplorerDo you folks with the Directv HDDVR 24-100 get a beeping sound when using the signal meter function? A DTV technician changed out my old dvr and I do not get any sound with the signal meter function.
- BobboExplorer IIIBILL.SATELLITE IS BACK!
- Bill_SatelliteExplorer II
dontexas wrote:
Want to use our HDDVR in TT instead of our SDDVR previously used.
Dish is 18 by 20 model AU2F3. HD receiver is HR24-100. Am I good to go ???
There is NO HD available with that antenna. It will only receive 101, 110 and 119 and you need 101 plus 99 and 103. 110 and 119 are no longer of much use. - buc1980ExplorerYou need the oval dish to receive the HD chanels
- IvylogExplorer IIIIf by three you mean three several inchs apart then for HD you need to replace with a SL3 LNB which will bolt on. I use this combo instead of the large slimline dish and a expensive tripod.
- donn0128Explorer IITriple LNB probably 4 outputs? Then you should be OK. Will just need to run two Coaxnto each receiver. As an alternative I would suggest instead upgrading to a wireless Genie and a slave for each TV you want. This, among other things will only require one coax from the dish and allow recording up to 5 programs at once.
- lanerdExplorer III'm not a Direct subscriber, but it sure sounds to me that you're good to go.
Ron - dontexasExplorerdonno128 this is a 3 lnb dish....... Worked fine on SDDVR....
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Jul 26, 2025
