- stevekkExplorerThanks everyone. I like iagary idea of a dedicated circuit. Thanks
I just saw today Walmart has a 50 inch smart Vizio 4K TV for $295 shipped or pickup in store.
So prices are coming down. - Bucky_BadgerExplorer
RLS7201 wrote:
TNGW1500SE wrote:
RLS7201 wrote:
.........Prices are cumming down..........
Was that a joke or a typo?
Neither. Just saw a 55" TV for $439.00. The price of flat screen TVs have been coming down for several years.
Richard
*coming - RLS7201Explorer II
Richard - iagaryExplorerI run a 24 inch TV, a 32 inch TV and my dish receiver which is powering an automatic portable antenna. I power all this at the same time if needed from a 300 watt Go Power pure sine wave inverter. I ran a dedicated circuit from the inverter to the entertainment area and to an outside outlet to run all this. It works great. No more running my generator just to watch a little TV. I have 2 - 6V golf cart batteries which power this all great.
- 2oldmanExplorer II
stevekk wrote:
SINE inverter, as in sine wave. Yes.
Thanks everyone. Guess I will think more about getting an inverter. Should I get a pure sign inverter? - TNGW1500SEExplorer
Was that a joke or a typo? - stevekkExplorerThanks everyone. Guess I will think more about getting an inverter. Should I get a pure sign inverter?
- ktmrfsExplorer IIIyes, Jensen makes 12V TV's.
many of the others even though they plug into the wall, run off 18ish volts, likely the same brick used for the majority of laptop PC's which often use 18ishV chargers.
so one could likely use a laptop charger with 12VDC in and the correct mating plug for the TV. I looked at that and decided to just keep using the inverter I installed in the trailer. - RLS7201Explorer II
garry1p wrote:
The brick (inverter)also acts as a regulator so by passing the brick into another 12VDC sources will give you unregulated 12VDC not sure how much tolerance the TV would have but the RV converter will put out over 14V at times.
If the TV comes wired for 12VDC and can be plugged into a 12V outlet it will have an internal regulator.
You are correct about the converter voltage. I run my converter & 15+ volts when off grid and my 120 volt with power supply in cord TVs have survived. Maybe it's because the wall wart is rated for 14 volts, not 12.
I have actually seen some TVs with in cord power supplies rated at 17 volts.
Richard - sch911ExplorerThis is a case where you should err on the side of getting a good TV such as Samsung, Sony, or LG. Forget the 12V hookup and go with a small inverter (as previously mentioned).
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,808 PostsLatest Activity: Sep 08, 2026
