DD716TED's avatar
DD716TED
Winegard Carryout Power Cable
The power plug on the antenna end of the 12 vdc power cable has pulled apart and requires replacement. Winegard says the only way to fix this problem is to purchase a a replacement cable which in time will fail again due to poor design. Has anyone replaced the plug on the antenna end of their Winegard Carryout power cable, and if so, where did you find the replacement plug?
  • That connector was always a problem. The new Carryout G2 uses a new and dramatically better connector.
  • FIXED!
    I have found a nice power connector that should not have the issues the Winegard power cable has.
    CNLINKO 2 pin power connector male plug and female socket waterproof outdoor IP67
    You just need to remove the original power connector and enlarge the existing hole to accept the new socket (do not remove too much material). Cut the wires off the original socket and solder to the new socket. Always keep the "hot" wires on the #1. Drill the 4 holes to bolt on the new socket. Seal the socket and the original mounting holes with silicone sealant.
    You then need to attach the cable connector - watch the polarity - hot on pin #1. The center of the cigarette lighter 12V connector.
    Link to ebay connector
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
