DesertMax's avatar
DesertMax
Winegard Movin View: How to change sat settings under dome?
My new rig has an old Movin View which has circular clock-like settings for the sats.
It is currently set to 119 and I have DTV so need 101.
Can I do this from the screen setup or under the dome?
The PDF shows the vertical type switches in a row that seem to indicate that this is how you change sats but my equipment under the dome only has the circular and they are not changeable..
  • Hey Bill, thanks as always up front.. Ok in the area of the 3 choices, the choices I made as shown in the photo are all that are available as choices. The DTV Tech told me that the choices shown are the correct choices.
    If you know something about some way of making other choices in this area such as 18" only as you have suggested, then DTV did not indicate this and I would like to know it.
    That tech also did suggest metering the coax which duplicates your recent recommendation. I will do that and let you know what I get..
    PS... Have you heard of Triniti Communications and their USB "Ursa" aparati? Finding lots of interesting tech features on YouTube
    especially in the area of free Internet tv etc.. A grain of salt!
  • I highly recommend that you follow my earlier suggestion to set the antenna type to 18" round. This will force it to look for 101 only which is all you need anyway.
    You might also want to go up on the roof, remove the dome and follow the coax cable into the electronics. With the receiver turned on (not the antenna), if you remove the coax at the electronics box, you should read 13-18VDC in the coax cable itself. If you do not then you have a cabling issue.
  • Hey Bill, here are all the screens including the one showing 02, 02 & Single. thnx
  • Hi Guys, I was able to set the sat to 101 under the dome and the DTV on screen menu verifies this. Still got an error 775 so although the receiver is talking to the tv, apparently not the dome..
    I guess that old dog's seen better days...
  • Small screwdriver that fits well into the arrow slot.
  • So you actually move those dials in the picture.. I thought about that the first time and today removed the dome cover once again but could not figure out any way to actually move them... grab hold of them...
  • Move the dials so the left is pointing at 1, the center pointing at 0 and the right pointing at 1. 101 just like it now reads 119. Be sure the power if off while you make the change and when you power it back up it will be looking for 101.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,793 PostsLatest Activity: Aug 22, 2023
