coachman05's avatar
coachman05
winegard sensar pro
I got a winegard sensar pro went to hook it up today followed the directions but, I cant get it to work. Im not sure if I did something or if the unit is bad. Hooked up the 2 wires the hot and ground wires but the unit would turn on. Hooked the old unit back up to it and it works fine. Any suggestions?
  • No the wires arent switched around and yes I pushed the select button to turn it on but, it doesnt turn on.
  • ktmrfs's avatar
    ktmrfs
    Explorer III
    you DID push a button (any button) on the sensar pro? for any of the led's to light up, you MUST push a button. it's still on, but in low power mode. the LED's don't stay on, they turn off after a few minutes.
  • 12V DC wires not reversed are they?
    If not reversed and you have 12V DC power then Sensor Pro should turn on.
About RV Must Haves
Have a product you cannot live without? Share it with the community!8,803 PostsLatest Activity: Aug 31, 2025
