Tonw07 wrote:
Well, here's what everyone was waiting for.......
I BOUGHT IT!!! I was able to get the guy down to $2,250 and I think that was a reasonable price if not a hair high.. I went and picked it up tonight. It started right up and I drove it home.(I actually didn't even make it a block before a guy stopped me and asked if it was sale. Good thing he didn't know his neighbor was selling!)
I got much more comfortable with the purchase after getting it going 55 down the highway (70 if you went off of the speedometer). I probably put 25 miles on it tonight without a hitch... well, other than the power steering leak which I found is just a bad hose so it should be an easy fix for that.
I dug a little deeper on everything and have found a hand full of different switches that I have no idea what they do so that might take a while to figure out but that will just come with time. Another issue I ran into is that the drivers side headlight fried after being on for a short while so I have to start looking around for a short for that but again, I'm not to concerned, especially that it doesn't get dark until after 10 PM here this time of year.
So here are a few pictures I took when I got home a bit ago.
Let me know what you guys think!
Also notice the awesome 89 conversion van that a few buddies and I went in on in the background to the right. It is loaded on the inside and is our weekend van with a great running 350 in it!.. Love that thing.
I haven't been to the site in quite some time so I'm catching up. Congratulations on your new toy. Your latest photos tell me a lot about it. I've had numerous version of these trucks through the years. The bady was slightly changed in '79 or 80 so fenders and such won't fit. Mechanically, the trucks were little changed until 1988 when they put roller lifters in the fuel injected engines. About 5 years ago, I finally sold my '84 (well the frame and title were 1984) truck with just shy of 400,000 miles. So if you're worried about durability, if you can work on it, it'll last for a LONG time.
You have a W200 chassis. Your rear end is a full floating axle. A little more trouble to do brakes but not much and it will handle anything you throw at it. Inside the drivers door should be a sticker or plate with the rear axle ratio. I'm going to assume you have 3.55 or 3.73 ratios. Your front axle will be slightly lower. This keep the transfer case from over running and keeps the chain tight. If your rear axle is 3.55, your front is 3.54.
Now, there is one trick you really need to know about your transfer case. When you've been running in 4 low for instance, and try to get out of it, if the lever won't come out of 4 low, back up. Just 30 or 40 feet will do it. The above mentioned ratio change keeps it tight and will bind the lever. Backing up releases it. It takes 10 seconds but with the current shift on the fly or electric shifting, people don't know about that.
I like the extra carrier on the back along with the spare tire mount. You do NOT want to pull a heavy trailer with the extension and it will cut down on your departure angle as you pull out of a ditch.
If you want different wheels, you have standard 8 lug wheels. They are common and used for many years on many trucks. 1/2 tons used proprietary bolt patterns but on the 8 lugs, there are only 3 or 4 bolt patterns. The wheels off my '01 3/4 ton will probably go right on it for instance. The same with 1 ton wheels. Just watch the off set.
90,000 miles isn't a problem. The timing chain usually lasts 120,000 miles on these engines. When you fix the exhaust leak, I'd pull the timing cover and replace the timing chain with a double roller unit. The parts guy will know what you mean. A worn chain won't let the engine run as warm so a new chain will give you better heat in the cab. When you put it back together, I'd put a new water pump on it. I'd also pull and clean the oil pan and get any build up out of it. That way, when winter rolls around again, you'll have all the problems taken care of.
If you have any questions, feel free to PM me. I don't get here often so it may be a while before I can reply (I work a LOT) but I've have numerous versions of these truck through the last 40 years.
