mikebrassard's avatar
mikebrassard
1993 Travelaire 454 chev p30 low power
Last year, I purchased a used 1993 travelaire 34' class 'A' MH w/t a chev 454, (TBI i believe) and has the 4 speed A/T. I live in western Canada, and have since made several trips into the rockies. I've never owned a class 'a' before, only an older class 'c'.
The biggest issue I seem to be having is lack of power, and that's where I'm looking for some assistance.
At first, I thought the issue might have been dirty gas. I replaced the fuel filter located on the frame (It was extremely dirty). I then ran a few cans of Sea-Foam through it, but no change in power - or very little.
The MH has 58000 kms on it (about 36K miles).
I realize this is a large machine, and GVWR i believe is 16000lbs, so it will not accelerate like a car, but it takes about a full minute to reach highway speeds (65-70 mph).
I've changed the cap, rotor, spark plugs, wires, air filter. A point worth noting - the engine runs perfect otherwise (no stumbles, misses, pinging, and starts perfect each time).
I have not checked compression.
It would almost appear that the engine is starved from fuel from what I perceive to be a lack of power, esp going up hills (at those times it also heats up and borders on going to red).
This summer, I would like to be able to tow a trailer behind, but not with this low power.
I know that a lot, if not most ppl will call BS, but this also seems relevant, my gas mileage is, in my opinion, absurdly high- 17.5 mpg (imperial gallons) averaged over 6500kms, that includes mountain and prairie driving.
My last MH, only 24 ft w/t a 350 chev had a ton more power, but only ran a best of 9 mpg. This is why Im thinking it is a fuel delivery problem.
If anyone can offer any suggestions, it would be greatly appreciated.
  • Check the fuel pressure first.
    Timing is ok?
    Read your plugs
    Does it have a cat? Early signs of plugging/disintegration?
    One lesson I learned the hard way and I always consider when I see any over heating condition is core/fin separation. It's very common with older radiators. With age or harsh/salt conditions the fins to cooling tube bond can be lost and the heat transfer from the tube through the fin and out to the air can be reduced. Check your radiator for loose fins that pull off the tubes easily.
    Be sure all the basics are there and then you probably get into making it breath better. I have never owned a MH with theses issues but it seems like the Banks kits and other tricks were very common back then.
    Random finds
    More
    Lean if too high of fuel pressure
