- wa8yxmExplorer IIIYes 30 amp plugs get fried.. This is common, Does not matter if you do it as you did or if it's a 30 amp RV into a 30 amp box.. 30 amp plugs get fried.
Epically if you do not clean them.. Cleaning them is important.. I've fried a few myself.. I have since started cleaning before plugging in and I carry a spare plug to boot.
Many threads around here about fried 30 amp plugs
(MY Rv is a 50, but I also have a 30 amp cord for it which I like to use on 30 amp sites cause the cord is a superflex and way easier to wrangle than that big stiff 50) - stevenicolExplorer
wa8yxm wrote:
If it is a portable unit... use a pair of dogbones.. (one 30-50 one 50-30) and not only will it work,,, perfectly... but these devices serve multiple functions.
ONE is spike supression (Fast short transint high voltage) and the 50 amp unit (when used on a 30 amp circuit) is far far better at this than the 30 amp unit is.
If it is a hard wired......
You have two legs.. Bridge them,, The current sensors,, Put 'em both on the combined wire.. It will still work just like the above.
This IS NOT A GOOD IDEA on our last outing, there were no 50 amp plugs, only 30; so, I plugged the 30 amp male to 50 amp femail dogbone into the 30 amp plug; the 50 amp Progressive industries surge-protector was plugged into the femail side of the 30 amp to 50 amp dog-bone; our 30 amp trailer cable was plugged into this. It all worked fine for about 4 or 5 hours, then the power went out. One of the dog bones femail plugs were fried to a crisp. We purchased a 30 amp power protector this week: lesson learned. - vic46Explorer
late bloomer wrote:
I have a 50 amp suppressor from a previous rv. My current rv has 30 amp service. Do I need a new suppressor, or can I use a 50 amp to 30 amp dogbone?
Make and model would be useful. - Mike3ExplorerSure thing. I use a 50 amp portable from Progressive Industries for my 50 amp fiver and thn add dog bones, in my case 2, for my 30 amp TC.
- tvman44ExplorerYes, go for it. :)
- wa8yxmExplorer IIIIf it is a portable unit... use a pair of dogbones.. (one 30-50 one 50-30) and not only will it work,,, perfectly... but these devices serve multiple functions.
You have two legs.. Bridge them,, The current sensors,, Put 'em both on the combined wire.. It will still work just like the above. - Mandalay_ParrExplorerYes, use a dogbone.
- DrewEExplorer IIIYou can use the dogbone, possibly in combination with a 30 to 50 to plug the suppressor into a 30A outlet.
If it's not an EMS that monitors voltage, but just a surge suppressor like a slightly glorified outlet strip surge suppressor, I'm not sure I would bother stringing together various adapters to use it. They don't provide a whole lot of value in my opinion. The EMS units that protect from overvoltage and undervoltage conditions, on the other hand, are quite worthwhile.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
