CincyGus
Mar 10, 2019Explorer II
If you absolutely NEVER dry camp, No there is not an advantage to spending the extra for the larger battery, unless as someone pointed out, the power goes out. I actually had that happen in a state park with full hookups once after a big storm. I was able to run fans, lights and all other 12v items for the 30 or so hours until power was restored. So that would be the only benefit I could point out, that it gives you a little extra cushion if your "plans" suddenly change.
About RV Newbies
