aftermath
Mar 12, 2019Explorer III
As always, you have heard lots of options. If you want to keep it simple, simply replace your 12v battery. Since you "never" dry camp you should be good to go.
If you want to improve things just a tad, replace your 12V with a true deep cycle battery, not a marine/deep cycle.
Of course you can continue up the ladder and get an AGM, a 31, two 12 volts, and don't forget solar power! Get a converter too while you are at it. How about a generator when the power goes out?
The answer to your original question is NO. Now go get something that works for you. Good luck in the hunt.
About RV Newbies
