Durb
May 17, 2023Explorer
We might want to consider the practical reasons as to why a park owner may require the sewer hose support:
If your hose has a pin hole, it will not be noticeable with an empty hose sloped to the outlet. If the hose is laying on the ground full of sewer water, a pin hole will cause it to leak its contents and create problems.
A full hose laying on a maintained lawn in a nice park will kill the grass below it.
A hose laying on the grass is more subject to weed whacker damage and leakage.
With the above being said, I bought a support as I was staying in a park that required it. Used it that one time and haven't used it since. I don't leave my hose hooked up and install it only when I intend to use it. Simple process and my outlet is low so I have to "walk it" every time. I also rinse my hose after every use so no solids are stuck on the inner ridges.
About RV Newbies
