Dutch_12078
Feb 10, 2018Explorer III
Choose a residential fridge that has dimensions the same or slightly smaller than the Norcold it'll replace, and then note the door thickness to locate where the hinges will be. The fridge specifications sometime make that easy by listing a depth with the doors off. Using that information, stretch out a tape measure to the width of fridge, hold one end approximately where the hinges will be, and see if it swings through a normal door opening arc with no obstruction. It has to at least allow enough opening swing to permit removal and replacement of full width shelves and/or bins. Our residential fridge door for instance clears the wall corner across from it by 1-1/2".
About RV Newbies
