A lot of fuel injected engines require a temperature of 180F to get out of the enriched "Choke on" setting, and get better mileage once above 180F. They are designed to have the thermostat recirculate the warm coolant back into the engine until it reaches 195F, then some will go into the radiator to get cooled off. After reaching 200, more goes into the radiator, and by 205 the maximum amount of coolant should be going into the radiator.
However as stated above, you can run 240F in some cars without overheating, it will be in the middle of "Normal" at 240, that is how that type of car works to get the best emmissions readings. Water at 15 PSI will not boil at 250F, and by using a mixture of anti-freese and water, the boiling point can exceed 280F when the pressure is high enough.
Your overheating issues can be because of the thermostat missing, and not slowing the coolant enough for adaquate heat transfer. My recommendation is the proper truck thermostat for your application. Your thermostat might be a larger internal diameter than a 454 gas car engine thermostat, even though they both fit under the same thermostat housing cover. Get one at Napa, or your local GMC dealer, they sell higher than average quality parts.
Fred.
