rscraig
Jun 19, 2013Explorer
4fromOH wrote:
Thanks everyone! I'm most concerned with the toilet. It seems like putting toilet bowl cleaner into my tanks might cause problems?
Most RV toilets have a rubber seal between the bowl and the flapper arm that opens when you flush. You don't want to use anything that causes that rubber seal to dry out or deteriorate. (Although it is fairly easy to replace if you need to.) Thetford, who makes most of the RV toilets, just recommends using soap and water or a "mild cleaner." They also make their own brand of cleaner specifically for RV toilets.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
