Johno02
May 28, 2016Explorer
Most roads that you would want to use with a Class A are suitable for big trucks. Unless otherwise noted and signed, bridges and overpasses are 14' usually, although I seen a lot of 13.5 ones. If the truck in front of you gets under it, then you can. Just watch for signs indicating low clearances. And, if you do find one that is posted low, believe the sign, and don't try it. If an overpass has bent edges and lots of scraped paint. go another way.
About RV Newbies
