Danasdaddy2002's avatar
May 10, 2013
Fuse box problems
Well guys I was getting the RV ready for tomorrow. It would have been our 1st time camping and it looks like it will be cancelled.
Went to power on the Fridge and it wouldn't. So I looked in the panel and seen this
No big deal right! I pulled the power from the house and disconnected the battery and replace the fuse. As soon and power was restored the new fuse blew. I tried 4 in total in frustration with no solution.
I called tech support and the guy had no help. He said to take it to a dealership which I will as soon as I can get an appointment. But until then I am willing to try any recommendation.
Everything worked last night. Today the fridge, and the thermostat the controls both the AC and Furnace won't display.
The box has the manafactories label WFCO T-30
Thanks a lot.
  • chevor wrote:
    Really?
    Isolate the circuit.
    !1 Unplug the fridge. Then replace the fuse. If it doesn't blow fridge is bad. If it does wires, outlet or something else on circuit is bad.
    Yup I tried that earlier today. Went outside to the fridge access panel and unplugged the cord. Went inside and added a new 15A fuse with the power off. Plugged er in and an instant pop and flash.
    I am stumped.but yeah that does take the fridge out off the possible problems. Thanks.
    The red led light that stays on next to the bad fuse slot must indicate something.
    Time for another google search.
  • Really?
  • The pol. fuses are both good.
    I thought it could be a bad battery so I disconnect the battery and ran directly from the house but that didn't work either.
  • pianotuna wrote:
    Hi,
    Is it the reverse polarity fuse that is blowing? If so are you certain you reconnected the battery bank with the correct polarity?
    It is fuse #6 which controls the fridge and AC.
    I only pulled one wire of the battery.
    I am doing a lot of research and I am just learning about the reverse polarity fuse. I am heading out to the RV right away.
    Thank you
  • Hi,
