- SlowBroExplorer IIIThe current battery needs to be replaced -- totally dead. Isn't a classic charger hard on batteries? Dries them out.
- NMDriverExplorerIf it is working and you are not replacing batteries, then I would not worry about it. My converter.charger lasted 15 years. Unless you plan on doing a lot of boonedocking and need a bank of expensive deep cell batteries, then a upgrade may be worth it. If you will mostly be on shore power in RV parks and only occasionally using your battery for a few hours in Wally World parking lot, I would leave well enough alone.
When my old converter died I did get a "smart" 3 stage unit, but I still do not think I have needed one. It is nice to see the light come on and tell me it is getting rid of the sulfur build up, or on float, or charging battery. - SlowBroExplorer IIIOk thanks all, I expect to be able to find that tonight and will try to post tomorrow or Monday with what I find in Google.
- wa8yxmExplorer IIISimple method.. Locate charger, and either GOOGLE or POST make and model
IE: Google; Make, model, speciications or
Google: make, Model, Owners manual - CA_TravelerExplorer IIIPost or look up the charger model number.
And discharge the batteries some and check the voltage at the battery terminals. About 14.8V for bulk and 13.6V for float. - BobboExplorer III
Dakota98 wrote:
Open the access panel to the converter & look for the make & model number of what's in it now.
What he ^^^^^^^^^^^^^^ said. There is no other way to tell. Post the make and model here and we will let you know what you have. - Dakota98ExplorerSince you purchased it used, how do you know if it's even original ?
All have a charging system, but it may not be 3-4 stage.
Converters may or may not have a built-in 3/4 stage charger. Some have a stand-alone charging system.
Open the access panel to the converter & look for the make & model number of what's in it now. - Rolling_CondoExplorer IINo, it won't have one unless the previous owner replaced it. Very few factory units have a 3 stage charger unless upgraded specially.
About RV Newbies
4,032 PostsLatest Activity: May 30, 2015
