- bukhrnNomadDrain valve on my Forester is right next to the tank.
- mobeewanExplorerI've had to replace the flexible tubing between the tank and pump a couple times because it just wouldn't keep a seal on the barbed fittings any more. Air was getting sucked through the joints and was keeping the pump from priming. After replacing the old used tubing with some not new, but unused left over tubing I had that was still soft and flexible the pump was able to draw water from the tank again.
- HorsedocExplorer IIAre you sure the pump is not airlocked and maybe not getting water to start the pump pulling water?
- ken56ExplorerI am with the person who asked if the winterizing valve was turned to the proper position. look on youtube for the procedure to dewinterize and check that valve too.
- wa8yxmExplorer IIIThere are several ways depending on your RV and it may not be necesary
Some ways: First my rig. If I follow the pipe from the tank outlet there is a quarter turn valve. I turn this and no water leaves the tank so now I can change pump safely (YIPPIE)
next is a T-fitting and the T-line runs to the pump. the Through line to another quarter turn valve to an outlet under the RV to drain (Come back tomorrow)
There is a 2nd outlet on the tank (I installed a petcock)
Some rigs if you crawl under there is either a capped pipe or a valve or both
Court of last resort.
Somewhere ABOVE the tank is a gravity fill.. Siphon hose.
But there should be a drain and a cut off valve to the pump. - bikendanExplorer
someuser001 wrote:
The tank is completely full. So I want to avoid driving down the highway with a full tank. I guess it should be ok. But seeing if I can empty it before for better gas mileage
For the pump. It keeps running. But no water comes out the tap. Any ideas how to debug? I was going to take it to a shop
This not a trailer but a class c. Where would I find this valve. I have looked below but cannot find it. Any ideas what it might look like?
Emptying the FW tank is not going to make any measurable improvement on fuel mileage. It's frontal air resistance that affects fuel mileage way more. - MarkTwainExplorer
pianotuna wrote:
let's assume a 40 us gallon tank. About 300 lbs of water
The weight (measured) of my RV is 13750 lbs. But let's round that down to 13000 lbs.
300/13000 = 2.3%
I think you may be hard pressed to measure the difference in mileage.
Totally agree:) I run with about 50 gallons of H20 with a 70 gallon tank. my Milage doesn't vary with tank 1/4 full or 1//2 full about 1 mile per gallon. I always want water to use bathroom when traveling and on occasion Have pulled over in a rest area in the summer and taken a shower when the weather is hot:) All trailers have a drain peacock or valve on the bottom of the tank. Some valves extend a little below the tank. - wopachopExplorerBefore you go paying a shop stick a vacuum on the faucet and use your hands to make a decent seal.
Turn both the water pump and vacuum on to prime the system. Happens to my friends trailer all the time. - LwiddisNavigator“But seeing if I can empty it before for better gas mileage”
Four hundred twenty odd pounds (50 gallons) isn’t going to make a difference in gas mileage. Dumping, driving, refilling will very boring very quickly. And forget that beautiful dry campground you just discovered...you don’t have any water. - nickthehunterNomad IIIWas the Valve for pumping antifreeze into the lines turned and not turned back?
About RV Newbies
