dodge_guy
Jan 12, 2015Explorer II
eHoefler wrote:
I would never use the dry weight on any trailer, I always use the max gross weight to determine towing capacity. Like some before had said, you will never travel at the dry weight.
To answer your question, No, you need a bigger truck.
Depending on the GVWR of the trailer I wouldn't go by that either. My trailer has a 4200 lb CCC. I only use 2k lbs of it. So as you can see using the GVWR is also not useful! I pack a lot. So normal "stuff" loaded in should be between 12-1500 lbs.
About RV Newbies
