SoundGuy
Mar 18, 2017Explorer
SoundGuy wrote:
Your 262BH has an entertainment center at the end of the bed platform so look for a wall plate with 12 vdc there.
kandkbrand wrote:
There is not one there. There is a 110 outlet and that is it. I would like to wire one in, but not sure how to go about doing it.
If there is no wall plate how do you switch the feed for the television between the antenna and cable? :h When switching to antenna 12 vdc is applied to the antenna head so obviously with 12 vdc available all you have to do is tap into that circuit. Also, if you have a radio in that entertainment centre it needs 12 vdc to run so there's no way there can't be a 12 vdc source in that area. Any of these sources would be suitable for powering a small inverter, otherwise for a larger one you'd be better off drawing 12 vdc power directly from the battery. Pics of your entertainment centre where the television is located would be helpful.
About RV Newbies
