I have recently purchased a fifth wheel trailer and need to replace the TV....is it essential to purchase a Jensen for RV's or can I go out and buy the most economical I can find?
Many LED TVs in the under 26" size come with an adapter (wall wart) to convert the 120vac to 12vdc or 14vdc that runs the TV. These can be run without the adapter directly from the 12vdc in the RV.
Look at the adapter before you buy, it should be marked with the output voltage. Make sure it is 12vdc or 14vdc.
