benjamlt66 wrote:
We have a 2019 Chaparral 336TSIK and are having some newby issues.
1. We are hooked to city water but when we set the water to "system fill" the tank doesn't seem to fill up. Do we need to turn the water pump on or are we doing something else wrong.
2. The thermostat has a setting for electric heat but it only seems to blow cold air. Is propane the only heating source?
3. We parked our RV in the lot for 3 days and when we came back the batteries were dead and we had to use jumpers to get power. We checked to make sure everything was off before we left the lot...what did we screw up?
4. Where is the manual point for raising/lowering the landing gear. Even the LazyDays tech we spoke to on the phone couldn't figure it out.
Thanks for any useful inputs/suggestions.
1. pics of the "system fill" would help
2. don't think you have electric heat. you should just have a propane furnace. only electric heat would be if your a/c had a heat strip. you need to set the thermostat t0 AU(Auto)
3. did you turn the battery disconnect switch to OFF? RVs have parasitic power drains that will drain a battery down in 2 or 3 days, if not plugged into shore power.
4. have no idea
