Thomas_NH
Nov 29, 2013Explorer
I wouldn't worry about it... It takes a real hard freeze (below 30 all day & night) before any damage can be done inside. The PEX tubing can expand with the freeze and not split. Faucets; well they are cheap junk anyways as well as the toilet, buy new ones that you like better. Drains; only the traps have water in them and open on both side and cheap to replace, but I doubt you'll have too. Holding tanks: no big deal there either, the worst that can happen is you could blow the valve seal, just take them apart and put in a $1.00 "O" ring...
You'd blow 10 times the repair amount just in fuel alone let alone the stress level you're causing yourself.
Take the advice from a licensed plumber (48 years) here in NH... Relax, don't be worrying about it.
About RV Newbies
4,032 PostsLatest Activity: Dec 23, 2025
