RCMAN46
Jul 08, 2015Explorer
At a minimum pop the dust caps and check the condition of the grease.
I just did this on a utility trailer that had been repacked 6 months ago. One of the dust caps had water in it. I found the grease seal had failed. I will check the dust caps before any long trip with a trailer from now on.
Also jack up each tire and check the wheel turns free and check for side play.
If you are not sure when the last repack was then by all means repack them and carefully check condition of bearings and brakes.
About RV Newbies
