Grit_dog
Jul 08, 2015Trailblazer
LarryJM wrote:jfkmk wrote:Grit dog wrote:
There is not a set answer here. Pop the caps and see how the grease looks. If it's all grey (metallic) and runny (compared to fresh grease) then it's time. Easy to check.
If the grease is still close to original color and not degraded then top it off with a few squirts and let er rip for 3 more years!
I disagree that sitting and not being used does any sort of real degradation to the bearings. Doesn't even make sense. That's like saying the grease goes bad in the bucket of tube after 2 years.
Just bought an 05 or 06 Sno machine trailer last year. Had like no miles on it. PO claimed 500 mi and I believe it.
Hubs/ bearings were never touched. Put a couple squirts of grease in each wheel to top them up and put maybe only 1500 mi on it since. No issues.
Never even took the hubs off my old sled trailer in close to 10 years and probably 15-20k miles, guessing. Just kept them greased.
RnR the hearings before heading to AK and re packed the hubs. Bearings were still fine and proceeded to put another 4-5kmi on it, loaded to the gills. No problems.
What??? Where on earth are you going to " put a couple of squirts of grease" to "top them up"? The OP never stated he has EZ Lube and since it's not a boat trailer he probably doesn't have Bearing Buddy's. Even with EZ Lube there is a procedure to follow, you don't just "top them up". The OP doesn't really have a clue about bearing maintenance (that's why he is asking), why would you tell him something so blatantly wrong?
You took the words right out of my mouth on this terrible advice of "put a couple of squirts of grease" to "top them up". While the OP has admitted not knowing much about bearing maintenance and has wisely asked for advice I'm amazed at the folks that are willing to jump in and give blatantly "BAD" advice and demonstrating they know as little or less than the OP that has at least wisely asked for advice.
For the OP as mentioned a lot of "book" answers say every year or so here is my take on this. First I use a moly fortified grease that meets the specs for the particular axle. IMO these EZ-Lube or equilivant axles at least for TT is an interesting idea in search of a reasonable application and TTs is not one of them. Reason is that it takes "A LOT OF GREASE" and as mentioned a very detailed and specific procedure to do it correctly. Also, when you do finally tear things down that is a lot of grease to get rid of and then reapply. My recommendation is to forget trying to use the EZ-Lube or equilivant feature and do a regular tear down and repack. I see no real reason to do this every year and my limit is around 20K miles total or 5 years which ever comes first except for the first one and that should be done as soon a possible so you have a good known starting point. These "personal" limits is something I have just developed a "FEEL FOR" over the 50+ years that I have been doing my own bearing maintenance on all my curent and past trailer and vehicles.
Larry
Well you 2 keyboard jockeys are obviously the trailer bearing authorities, lol. (Like the weight police and them guys that weigh every ounce of they're putting on the truck including whether him and the ole lady had their BM for the day yet!)
Since ole Larry goes 5 years and 20k before looking at the bearings then that is what you should do! Oh wait, that sounds like worse advice than inspecting and periodically adding grease......... Whoever said that!
As long a you got a "feel" for it we will all be fine!
That's why I love this forum. It's pure entertainment!
Oh and if you can't figure out how to add grease to a trailer wheel without a bearing buddy or easy lube then you shouldn't be giving out advice!
About RV Newbies
