Charlie_D_
Jul 16, 2015Explorer
One of the things I don't see very often is people speaking about how much grease should be used. The EZ lube system speaks about greasing until fresh grease is seen. Over greasing causes the grease to churn and can cause them to overheat. If one could see the amount of grease seen in a shielded bearing they would see how little grease is used and needed. Pop a shield on a shielded bearing the size of a trailer bearing and the amount would be as small as a marble.
About RV Newbies
