tylerm96's avatar
tylerm96
Regular Microwaves vs RV Microwaves
Hi everyone!
Bought an RV last month and now have to get a bunch of stuff including a decent microwave. I browsed some online stores like ***Link Removed*** and noticed that the prices on RV microwaves are on average 50-70 dollars higher compared to regular ones.
Are there any major differences or it is just a marketing trick?
I don't need anything fancy, just want it to work.
Also, I'd appreciate any recommendations.
Thanks
  • shum02 wrote:
    StirCrazy wrote:
    wa8yxm wrote:
    What is the difference between an RV microwave like the Dometic CDMW12B and a Home Microwave like the LG CDMW12B (note they are the same model number)
    The door on the Dometic says DOMETIC and the one on the LG says LG.
    Now because of the way the dometic was originally mounted the installer did some sheet metal work to duct exhaust air but the microwave itself is identical to the Lucky Goldstar. and in case you are wondering I've never been lucky enough to have Goldstar products work (So the one that is now in my apartment kitchen is a CDMW12B/yxm the suffix means I re-designed part of it, did some machining and replaced one LG part with a GE part, now it works great).
    But the reason for the ducting is originally the unit was installed in a closed cabinet the mounting flange had vents and they routed exhaust air into the flange... AMANA's vent to the front (At least the 2 I had did). so that would not be needed
    if the compartment is open.. you don't need to do that (I eventually opened the compartment)
    but the mirowave... Is identical save for the name Dometic on the door . Oh and the price tag.
    then you get greystone, which is not the same as any other brand for issues like the motherboard. mine recently went, but it was just a lose wire in a cheep plug. if it would have been the motherboard it would have been junk because the repair shop couldnt trase the numbers on it to anywhere. some times I envy your prices in the US, 40 bucks for microwave that would cost 150.00 here and the rv ones are about 450.00
    Steve
    I bought a microwave at Cdn Tire a while back for $75. If I wait for a sale bet I could push $65. With exchange that is about the same. MasterChef house brand.
    ya I looked at a walmart one and at another place but they were all to small to fit my trim, costco had one but it wasn't 100 or less and the cheep ones while 10 years ago used to be all over I find by the time you pay taxes here in BC most are over 100 getting close to 150 that are the right size to replace mine. I was just shocked when a rv dealership told me it would be 450 plus tax to get it from them....
    Steve
    Steve
    Steve
  • When my RV Samsung quit I replaced it with a $30 microwave from Walmart. It worked great in my Rv.
  • I’m seeing less and less of microwaves being vented to the outside. While ours has a fan, it sucks cooking fumes through a filter much the same way most home microwaves do with no venting to the outside.
  • wa8yxm's avatar
    wa8yxm
    Explorer III
  • JaxDad's avatar
    JaxDad
    Explorer III
    It's not talked about much but most microwave manufacturers offer a 'built-in' kit to allow for flush mount installation in cabinetry.
    The one in my S & B is this way, it also vents to the outside not back into the kitchen.
  • Most RV microwaves are cheap junk, the one thing that may be different is that there may be venting for those mounted in a cabinet. If you buy one meant for home use, be sure that it will vent properly.
  • My RV microwave does have a venting system. Since the turntable has died, I will be replacing it with something from Walmart that most nearly fits the space. I may get a Panasonic because that make uses inverter technology so running at lower power doesn't "pulse" on and off, it actually consumes less power when set to 80% or 40%.
    If I can't find one to fit--then I'll buy the cheapest one that does fit.
