wickedstang03's avatar
Jun 13, 2015
Replacement bulbs
Anyone know what bulb the outside porch lights take? Im talking about the one that is in the front of the camper by the propane tanks it has a manual switch and is not tied into the light switch that turns on the outside light.... switched everything else to leds just need that one now snd the over head range light above the stove I believe its a 921..
  • Dakota98 wrote:
    Remove the plastic cover & pull the bulb.
    x2
    and look at the bottom of the bulb to see the config of the contacts to make sure you replace it with the correct one.
