Randu wrote:
I've got one and use it at least once a day to give the bowl a good rinse. If you watch, the water flows in small streams about 2" apart (at least on mine) which leaves a lot of surface area that don't rinse. Urine splatters in area that don't get rinsed make toilet area smell bad. Its a nice extra to have. Randu
The 310 takes care of that handily (for the urine at least). It squirts the water out sideways along the bowl and as the water drops down it covers the full bowl. Probably one of the better ideas for rv's in a really long time. It also helps to swirl the bowl contents to help detach it from the bowl walls which reduces the amount of bear clawing.
