RJCorazza wrote:
With (20) Lego style blocks I was frequently coming up short for the stabilizer jacks. I opted to buy a pair of Anderson Levelers to free up more blocks. I haven't tried them yet, but they should be awesome.
I'd have invested in a set of Andersen Levelers myself by now but with our trailer having a narrow 29" axle spread there just isn't enough room between the tires to prevent the rear Anderson from getting jammed between the tires. Yeah, I know - Andersen does include instructions for cutting as much as 5" off the tip but I'm just not prepared to do that as the more that's cut off the greater is the minimum lift with that leveler. I'd instead round the bottom edge of the thick end as some owners have done but in my case that still wouldn't provide anywhere near the clearance needed. Andersen Levelers are surprisingly heavy for what they are but they're also slick and will slip easily on any hard surface ... they also don't offer a particularly large footprint and can sink into soft ground surfaces. Some use wood under each Andersen to prevent this but since wood itself is slick I'd instead use 3/4" thick
outdoor stair tread made of recycled rubber - heavy and textured much like roof shingles, can easily be cut to size, and available at home building supply places like Home Depot, Lowes, etc.
