JimK-NY
Jun 11, 2019Explorer II
There is a huge issue with RV tires. Tires can deteriorate when they are not used. They can actually live much longer if they are used at highway speeds fairly frequently. The heat helps draw chemicals to the surface which protect against dry rot. A tire that is not used can deteriorate in 4 years. I learned that the hard way when I tried to use a 4 year old spare tire.
When I researched the issue, I could not find anything positive about most tire treatments extending tire life. In fact there were some warnings that solvent based materials can accelerate deterioration. I did find positive support for Aerospace 303 which is water based. In order to be of value, you must first clean the tires on both sides and then apply the 303 on both sidewalls. You need to repeat about every 6 weeks.
BTW, the other method of extending tire life is to use a fabric cover. That will block UV rays but I doubt it will do much to extend tire life. My spare was stored under the truck and was never exposed to direct light.
About RV Newbies
