Steve_83406
Aug 07, 2017Explorer
I replaced a Thetford Aquamagic IV (high model) with a Dometic 310. Very pleased with the results. The scariest part was cutting the old gray polybutylene pipe to put the new compression fitting on for the water connection. The 310 is easier to clean (IMHO), and as it is about 2" taller, it is easier to use. I do note the Dometic comes with 1/4" diameter T-bolts for mounting (at least mine did), which I replaced with 5/16" diameter T-bolts just to make the toilet a bit more secure. I also "dampened" the entire gasket with silicone grease to help ensure a good seal.
Steve
Steve
About RV Newbies
