rockhillmanor
Nov 03, 2015Explorer II
Thank you OP for not being afraid to post about a frozen water line.
Hmmm. Finally an honest post from someone who used the blow out the lines method of winterizing and experienced a broken water line. Most won't admit it!
Perhaps a good reminder for why using the pink stuff, that actually goes into each and every part of the water lines, just might be a better way winterize? :W:B
All you do is open all the faucets and run toilet until the water turns pink. That also puts antifreeze in the p-traps and toilet bowl. Done.
It is why "I" use the pink stuff method.
About RV Newbies
