rseymour21
Nov 05, 2015Explorer
rockhillmanor wrote:
Thank you OP for not being afraid to post about a frozen water line.
Hmmm. Finally an honest post from someone who used the blow out the lines method of winterizing and experienced a broken water line. Most won't admit it!
Perhaps a good reminder for why using the pink stuff, that actually goes into each and every part of the water lines, just might be a better way winterize? :W:B
All you do is open all the faucets and run toilet until the water turns pink. That also puts antifreeze in the p-traps and toilet bowl. Done.
It is why "I" use the pink stuff method.
I thought he missed winterizing the toilet. The Pink stuff wouldn't help in that case! ie, if you don't blow out that part of the line or if you don't run pink stuff to that part of the line, same result.
About RV Newbies
