JaxDad
Nov 20, 2015Explorer III
Bobbo wrote:
Blowing out the lines is easier to not do properly.
If you blow out the lines till no more water is seen coming out of the outlets, it is still possible for enough water to remain to collect in a low spot to do damage.
That statement says it all right there.
The method is not the issue, using that method improperly is the problem.
BTW, from a technical point of view, the last sentence is an impossibility if the task is done correctly, using a sufficient pressure and volume of air, and blowing the lines LONG ENOUGH.
I constantly see and hear of people using a little $79 compressor and just giving a short blast of air then wondering we they've had freeze damage.
About RV Newbies
