cs2kplus wrote:
Thanks again allworth. I think we are set on the 250/2500 2000+. Any preference as to GM/Ford/Dodge?
Oh...on another note....our trailor has a 2-5/16" ball fitting. It came equipped with side bars (I was told they are to control sway - but not necessarily sway bars) If the truck I get has a hitch - should it be 2"? 2-1/2"? 3"? I assume this is a simple straight adapter that plugs into this and would have the 2-5/16" ball?
2 and 2 5/16 balls will fit on the same hitch but the larger is a heavier capacity.
On the 1500/2500/3500 part. In the 90's, trucks started to be named by what they are designed to haul continuosly. A 2500 model is built to handle 2500 pounds on a regular basis. Such as a welding truck with mounted welder. The higher ratings have increased springs but also heavier brakes to handle the extra inertia to overcome.
The bars are probably equalizer bars for an equalizer hitch. The bars came from the hitch to the tongue of the trailer a bit back from the coupler. Essentially, what these do is transfer some of the tongue weight to the front of the truck. This lets the front axle carry some weight. This massively improves safety and handling. Instead of way down in the back with your headlights looking for possums in the trees, you drive more level. The extra weight on the front also helps keep side winds from causing you to change lanes when you don't want to. With a 6500+ tow, you really want the equalizer hitch. Instead of the little square doo hicky, these are often quite massive hunks of metal. I've got one I've had for 25+ years and I've hauled some huge loads with small vehicles. I towed a 1963 Imperial sedan (Chrysler product) on a car trailer, with proper brakes,with a 1988 S-10 pickup with a 2.8 and manual transmission. I didn't go very fast but it handled ot just fine. It looked like a Yorkie being chased by a Great Dane. The key is to balance the load on the trailer and use the equalizer hitch.
