ScottG's avatar
ScottG
Nomad
Jun 05, 2014
$119 eBay replacement awning material
I installed the product from this eBay seller: Awning to replace my Dometic A&E 8300 series and I thought I'd give a few details about the item.
First, the seller says this awning is made from heavier material than the original but it's not. The orig is .018" and the new stuff is .014". This doesn't sound like a lot but you can definitely feel the difference (not a deal breaker though).
Then there's the "fade" coloring. The color isn't nearly as dark as the images on-line and I would have liked it a bit darker but it's not a big deal.
This awning is advertised as having a vinyl "weather shield". You can see in my second image that the WS lets a lot of light through, which I kinda of like but if your needs/tastes may differ. This WS also causes the awning to have s seam about two feet down from the roof. A bit unsightly IMO.
All in all, I think the product is fine for the money (orig will cost 4~6 times as much) and looks pretty good. It fit well and the sides were actually seamed straighter than the original.
Still needs to bake in the sun and get the wrinkles out:
View from underside - note light coming through weather shield:
My TT smells like new again!
Hope this helps anybody that was considering this option.
Cheers,
Scott
  • So, it was just the material? You needed to install on your "roller" and brackets? Sounds like a deal.
