- camperforlifeExplorerOn my '11 measuring from where the large mirror & small mirror meet, I measured from the outside edge of the mirror along the arm to the door glass. At the normal extended stop point it measures 21". You can push the mirror forward to get 22.5".
- hawkeye-08Explorer III
I went out and checked, after some pulling, mine fold forward also, never thought about doing that. I will try it next time we go out.
Thanks much. - WishinExplorerMine are the same 8'10" as ktmrfs'.
They are wide enough I feel safe, and have no plans to change them. I still with they would go out a few more inches.
Mine are only about 18" from the glass however. - Mr_BeeboExplorerCompared to the paddle type mirrors on my old half ton, the towing mirrors do a wonderful job. So, yes, I can see down both sides of the camper and known if a car is trailing me.
- wandering1ExplorerIf you have the optional towing mirrors then pull them out further.
- nomad297Explorer
N-Trouble wrote:
nomad297 wrote:
Look at the Fit System mirrors at Amazon. I have them and they are awesome. They look like stock mirrors. They are heated, have the turn arrow and you control them just like you do your OEM mirrors.
Bruce
In regards to what the OP is asking about extension length these are no different than the factory OEM mirrors. They are just clones of what he already has.
No, these go out much farther. Would anybody like me to measure what they are for comparison?
Bruce - ktmrfsExplorer II
nomad297 wrote:
N-Trouble wrote:
Bruce
Bruce
I'd like to see a measurement. They look identical to the factory camping mirrors. - nomad297Explorer
ktmrfs wrote:
nomad297 wrote:
N-Trouble wrote:
Bruce
Bruce
Ok, here are the measurements as mounted on my 2004 Chevrolet 2500HD:
The overall size of the glass in each mirror is roughly 8"x12"
Without the mirrors extended, the out to out measurement is 8' 1-1/2"
With the mirrors extended, the out to out measurement is 8' 8-1/2"
Measured perpendicularly off the window without the mirror extended, the measurement to the outside of the mirror is 16".
Measured perpendicularly off the window when the mirror is extended, the measurement to the outside of the mirror is 20".
How does,that compare to the OEM mirrors?
nomad297 wrote:
'ktmrfs wrote:
nomad297 wrote:
N-Trouble wrote:
Bruce
Bruce
Bruce
within fractions of factory towing mirrors mirrors. on my 04 Silverado,
perpendicular to the window is 20" just like your measurement
out to out through the cab is 8'10" from plastic to plastic, about 1" shorter if measured to edge of glass. - hawkeye-08Explorer IIII tried extending my mirrors (folding forward) to gain slightly more width, but the adjustment did not allow me to see back (they would not angle in enough to be useful). Thanks for the ideas though.
Looking for advice before your next adventure? Look no further.25,102 PostsLatest Activity: Jan 18, 2025
