Mike_and_Trish's avatar
May 25, 2014
2014 Honda CR-V baseplate
So we made a deal on a new 2014 Honda CR-V yesterday, picking it up tomorrow. (Trading in our well-used 2008 Jeep Liberty, which served as both toad and daily driver for 6 years.) We will use our existing Blue Ox Aventa towbar, so looking to have a baseplate installed on the CR-V ASAP.
My concern is this -- I just downloaded the Blue Ox installation instructions for the CR-V baseplate, and what caught my eye was that "the bumper is removed and not reinstalled." Apparently, the baseplate replaces the bumper? (I guess unlike "bumpers" of old, today the term seems to only refer to the metal framing behind the flexible plastic shroud that we see on the front of the vehicle.)
With all the emphasis on vehicle crash ratings, etc., the idea of throwing away a perfectly good bumper worries me a bit. Can anyone shed any light on this, and/or relieve my anxiety?
  • Thanks all for the responses. Ordered through dealer yesterday, they will install baseplate and wiring kit third week of June. Still undecided about which way to go on toad brakes -- got new RV last fall, was waiting 'til now to decide after replacing toad. Any thoughts welcome ...
  • Dick
    Good idea!
    In a front end collision in the Class A, I plan on lifting up my feet to let the accident happen below me, and then ducking when the microwave comes forward. . . timing is everything.
    I don't have a plan for the CR-V yet. . . probably just the fetal position.
  • I don't worry about it on my 13 CR-V. If you want to use it as a toad that is what you need to do. It tows great. Yes it may not crumple as designed just don't get in an accident. Dick
  • othertonka wrote:
    the bumper that you remove is inside and is just pressed metal. My Roadmaster base plate has a bumper included that in my opinion is stronger than the factory bumper. But I would save the bumper to have it reinstalled when or if you ever remove the base plate
    I agree. It's probably stiffer than the metal box beam bumper. It actually might not crumple as the original was intended to do in an accident?
  • j-d's avatar
    j-d
    Explorer II
    I second what everybody wrote above. Downloaded the instructions and also looked at the Aventa towbar.
    1. The Base Plate will more than replace the "Bumper" strength-wise
    2. Keep the "Bumper" if you have a storage place for it
    3. Aventa Tow Bar avoids any of the issues listed in the Install Notes
    Towing-Wise, You are Good To Go!
    What are you doing about...
    Braking?
    Lighting?
  • Same with our 08 CR-V w/Roadmaster BP. Bumper is leaning in the corner of the garage.
  • Anyone have pix available? Our 2006 is looking at its golden years
  • the bumper that you remove is inside and is just pressed metal. My Roadmaster base plate has a bumper included that in my opinion is stronger than the factory bumper. But I would save the bumper to have it reinstalled when or if you ever remove the base plate
  • I was given the bumper from our 2013 CRV when I had the base plate installed. This was for a Roadmaster setup. I was told the bumper could be reattached should I want to but, what are the chances the baseplate would fit a new toad several years later? I will probably just leave it setup as a dinghy and consider that a selling point. You are right that the baseplate gear is now the bumper.
