Old-Biscuit
Jul 13, 2015Explorer III
LP Detector is know parasitic drain but not that quick....more like week(s)
TV Antenna booster ON?
Any lights in storage compartments?
Any lights by dump valves....front area?
Otherwise.....
Overnight drain......you have insulation worn thru....bare wire touching frame/metal
Need to check amp drain by connecting a multimeter between Battery Neg post and negative cable.
Then remove DC fuses one at a time until amps drop
Otherwise.....
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
