ktmrfs
Jul 13, 2015Explorer III
stereo. the "off" position is really only standby. however, it should take 4-5 days to drain a single 12V battery. drain is not insignificant.
Next is leaving the antenna box in the cable position, it again will draw enough to slowly drain the battery.
most keystones built after about 2013 have a external battery disconnect switch. check to see if your does.
and tv. if it is a 12V TV make sure it is really OFF, not standby
also, the standard WFCO charger is not likely to fully charge a single battery discharged to less than 50% in 24hours, more like 48 hours. virtually impossible to get them into the boost mode with 55A output, instead it will default to 13.2V and 10A or so tapering down.
Looking for advice before your next adventure? Look no further.25,199 PostsLatest Activity: Jan 17, 2025
