burlmart
Jul 15, 2015Explorer
i am wndering if the truck alternator charges the house battery when towing. if so, there may be a malfunctioning isolator solenoid stuck on , or a malfunctioning electrical diode or something like that.
with such high current drain, i'd be surprised if you don't get bad sparks disconnecting the battery positive terminal ( be careful if you try}.
to measure current with many mulitmeters like you tried w/ negative term disconnect, you set meter to read DC amps and move the red probe to a different plug opening. read user manual. you will have only 10 seconds to measure this, as it heats up multimeter (at least my walmart is like this)
Looking for advice before your next adventure? Look no further.25,214 PostsLatest Activity: Sep 21, 2026
